Clears L2PT counters.
| vpls | Optionally clears counters only on a specific VPLS. |
| vpls_name | Alpha numeric string identifying VPLS VPN. |
| peer ipaddress | Optionally clears counters only on a specific peer of the VPLS. The variable specifies an IPv4 address. |
| vpws vpws_name | Optionally clears counters only on a specific VPWS. The variable is an alphanumeric string identifying the VPWS VPN. |
Disabled.
Use this command to clear L2PT counters.
The following example clears L2PT counters on peer 1.1.1.1 of VPLS vpls1:
clear l2pt counters vpls vpls1 peer 1.1.1.1
This command was first available in ExtremeXOS 15.5.
